johnson 200 1995 won't stay running
vegas boat guy
i have a johnson 200 venom i have replaced the volt reg the stairs the vro pump and clean the carbs it seems to be losing fuel presure it runs for few seconds and peters out :confused: :confused: i can keep it runnin by working the choke or pumping the bulb i have spent a ton of $$$$$ and can't get it run
roscoe
Re: johnson 200 1995 won't stay running
Hi boat guy.<br /><br />Best for you to post this question over in the Johnson/Evinrude repair forum. That is where the tech guys hang out, and will get more exposure from the guys who know.
JB
Howdy, boat guy.<br /><br />Welcome to iboats. :) <br /><br />We post engine troubles in the Troubles forum.<br /><br />I will move this for you.
andy6374
Are you saying you have do both to keep the engine running?<br /><br />If pumping the primer keeps the engine alive this is indicative of an ailing fuel pump and it needs rebuilding.<br /><br />If choking the engine saves it this means the carbs are dirty.
vegas boat guy
Originally posted by JB:<br /> Howdy, boat guy.<br /><br />Welcome to iboats. :) <br /><br />We post engine troubles in the Troubles forum.<br /><br />I will move this for you.
roscoe
You are there now.<br />Move from forum to forum by using the drop down menu at the lower right of this page, it is labeled "Move to Other Topic."<br /><br />You initially posted in the discussion/non-repair forum, you are in the right place now. No problem.<br /><br />As andy stated above, time to rebuild the fuel pump.<br />Pretty easy, just pick up a fuel pump kit from the dealer.
