Johnson 1999 30 hp boat motor
rfhoff
I have a 1999 Johnson 30 hp boat motor. I replaced the fuel line but it still does not work right. It starts right up, will run very slow but as soon as I throttle up it dies. Starts right back up and does the same thing. Will only run very slow. Any suggestions as to the problem?
jakedaawg
Make sure arrow on fuel primer bulb points to motor.
As said above, open air gap spark check set at 7/16"
Compression test also reccomended.
Report results back.
You might also try pushing in on key while trying to accelerate. If that seems to help it would typically point you in a fuel related direction.
gm280
It would be interesting to verify fuel issue or spark issue. If fuel, it may be time to install a carb kit.
And :welcome: to iboats. Glad you joined us...
rfhoff
Thanks for all the input. Will give suggestions a try altho I did install new plugs.
