thatone123
Banned
- Mar 7, 2009
- 707
These are the plastic top and fuel bowl models. Cleaned carb but from previous experience with these (not good with similiar problem) I almost felt the carb cleaning would not get the carb to run right. It starts easy with choke out but will only keep running with choke out. You can use the choke as a kind of throttle. But then it will die when you let go of choke. Checked for air leaks, good compression and plugs etc.
