First love the Iboats forums it's help me numerus times. Ok here is my issue. I've had the boat for about 3 months. I've always had a hard time getting it started but once it is going not a problem until i stop and try to start again. So wether it's cold or hot it doesn't want to start. The carbs were rebuilt. Last wkend I made some headway determining if it was gas or spark issue. If I pump the ball hard and turn my red choke dial on the engine I can hear the gas squirt into the carbs. I do this while playing with the throttle as the wife turns the key. It takes about 3 times then i play with the throttle for a few seconds and we are running. I've tried holding in the key for the 5 second and much longer but doesn't work. I'm going to disconnect the gas out line on the choke and activate with the key to make sure gas is passing thru in the morning. I can hear it click but haven't visual checked. The next thing I was going to do was rebuild the fuel pump. Any idea would be helpful. Thanks
