Johnson 1986 90HP V4 VRO Battery Cable
wanenz
hi - I am going to replace the above cable as it is damaged - after pricing an OMC part (exhorbitant price ) i have decided to make my own up - does anyone know the starting current of the above so I can get the correct cable? thanks
rodbolt
Re: Johnson 1986 90HP V4 VRO Battery Cable
Hello<br /> yes some of the cables are a bit pricy. most shops here use a #4 cable. if the wire run is under 6 ft. there is a chart around for that.as to the excact starting current I dont know and all my manuals are not here with me.<br /> good luck and keep posting
wanenz
Thanks for the reply - I have decided to use 25mm2 Welding cable - only $7 / meter (nzd) - nice and flexible and able to take extremely high currents.
Dhadley
The welding cable is a good choice. We've used it many times on stock cars and in boats with long cable runs.<br /><br />Good luck!
AUGIDAWG
http://www.cablecotech.com/powdistprod.html <br /><br />Check out the PowerFlex cable, and the FusionLug.<br />We use this stuff at work. It's great flexible wire.<br /><br />The FusionLug is created from the copper wire, using some high pressure press, and then solder dipped. There are no crimped-on lugs, or soldered-on lugs to create problems.<br />They have charts to help you with size recommendations, and current carrying capabilities. Note that these charts are for constant full time loads, and are very conservative.<br />4 gauge will work just fine.
wanenz
Thanks everyone for the good Replies - used the welding cable and worked a treat.
