hello,
I am trying to remove the lower unit so I can do maintenance and change the water pump. It is extremely hard to get off. Attached a picture on how far I get it off (approximately 2 cm) - I have also set the motor upside down and sprayed quite some crc spray in the area where the shafts are hoping it will loosen things up - I have read there is no other way than to be decisive and hammer it off.
Is that the only way or any other good advice that could help me?
thanks in advance for reply.
