Re: Johnson 1985-120hp V-4....water pressure
Hi Boseefus<br /><br />I think djohns is right. You have a restriction between the pump outlet and exhaust cover inlet, or a leak.<br /><br />>is it possible that the tube seal is missing out of the water pump housing?<br />>how did the impellors look when you've changed them? were any busted up, pieces missing?<br />>is it possible that the relief valves are not installed properly?<br /><br />If the above were OK, I'd pull the exhaust covers and leg. I'd blow with shop air from the exhaust cover water inlet and see if you have a free passage to the leg water tube.<br /><br />There are several passages throughout the engine and middle section that could house a restriction or provide a large bypass. I would check the easiest first.<br /><br />>check valve assembly<br />>seal in top of waterpump outlet<br />>remove exhaust cover and leg, and blow from exhaust inlet to water tube. If a restriction is noted (poor volume coming out the water tube) you could try using a pressure washer (car wash wand) to blow out obstructing pieces. (gonna require new exhaust cover gaskets)<br /><br />This is just my opinion, others may have better!!<br />Good luck
