Johnson 1982 50hp problem getting full throttle
Twillis93
Here is the problem the engine starts up fine, idles fine. I can get it to move the boat around good, In the no wake zone. once out of the no wake zone. I'll give it some gas. well it gets going really well then about 20 30 seconds it drops to less then half throttle, with the throttle at full. It drops and it starts I guess it would be reving, trying to achieve that full throttle. it'll have a break through to where it roar a little loud and have a little Getty up then it'll get back down.
I checked my tank to see if the valve was open, and mashed the primer ball no help. I checked my hoses and sealed my connects with solvent seal. New gas New oil at 50 to 1. Have checked and cleaned my carburetors, Will go over again and soak in carburetor cleaner. couldn't hurt right?
Then when getting back home I noticed this black goo from behind the lower unit. coming from that water port on the back side. Some will also be coming from the exhaust port behind the prop.
I will get a video loaded up here pretty quick hopefully.
Thanks for the help any suggestions would be greatly appreciated.
Boat info my boar is a flat bottom polar craft 16 foot so it should push it no problems. Kinda scary actually when it gets going.
The problems start at :25 seconds in the video.
