johnson 1978 4hp
rtpogo11
hello to everyone my question i have a motor that will run smooth when the bulb is hard on tank the motor starts pooping out when bulb goes soft is it the carb or the fuel pump if it is the fuel pump any idea thanks
Vic.S
Re: johnson 1978 4hp
If you can keep it running by pumping the bulb then suspect the fuel pump or air ingress into the fuel line.
Check also that there is no restriction to the fuel pick up from the tank and that the tank vent is open especially, if the bulb is tending to flatten.
Checked the filter on the pump?
rtpogo11
i have the service manual but iam not sure how to check a fuel pump do i just look at it see if it looks good i had the motor running on another tank it did it once and awhile on that tank and hose but that is a yr ago
