Johnson 1976 115HP Gearcase Removal
ltovey
Dear All<br /><br />I have just purchased a 115PH V4 Seahorse made in 1976. It seemed to run okay, but I decided to rebuild it for both knowledge, and the peace of mind. I've got as far as removing the gearcase. I believe that I have followed the manual to the letter, however the gearcase dropped only about two inches, and seems to be still retained somewhere. Any ideas ?
Chinewalker
Re: Johnson 1976 115HP Gearcase Removal
Have you disconnected the shift rod? Disconnect is located under the bottom carb...<br />- Scott
