Johnson 1971 9.5 points
dukekas
The motor set for about ten years. Lubed and worked everything in. Only one plug firring, checked points, messed them up, now the good cyl wont even fire. Cam has top marked on it. Is that the part you align with the felt boot? Originally one set of points were touching.
bradmond
Re: Johnson 1971 9.5 points
Set the points to .020" with the lobe positioned so the points are opened to the maximum. So you set each points seperate, adjust one set, rotate 180 degree, and adjust the other.
dukekas
That make since, Thank you very much. So Originally when one set of points were touching, it was cam position? Odds are maybe a dirty point or bad coil, why the other dosent fire.
ezeke
If the points are correct, make sure that the coils are set correctly so that they pass the flywheel magnets at the correct distance. Click the thumbnail. The alignment should be exact.
bradmond
I would replace both points and condensers with OEM parts. Check coils for cracks in the plastic and replace only if cracked.
dukekas
That was right on how you told me to set the points. The god cyl is sparking again. The magnet placement is right on. Tested bad cyl with known good plug, nothing. Im 100 percent confident the points are right, Thank you a million times over. Ive seen coil packs go out on fords, not really GM, whats the likely hood of a bad plug wire or coil pack? I have a 1969 Evinrude 9.5, coil packs swappable to trouble shoot?
dukekas
Oh i see, ignition tune up kit. ;) Coil packs are intact
jmendoza
A bad condensor will cause a weak or no spark condition.
Chinewalker
Although rare, the coils from that era can go bad. Usually, it is obvious - they'll have a crack in them or be otherwise physically compromised. More than likely your points are dirty or the condenser is bad. I would install a new set of points and condensers and go from there...
dukekas
Thanks for all your help guys. Points and condensers, plugs and alot of pulling. Purrs like a kitten. Seems to run better with choke 3/4 closed but, havent got it up to temp yet. Summer just got a little better for this old vet.
