Johnson 1958 35HP Super Seahorse Carb Flooding
sahammo
OK i have two questions first is my motor was running great and then it started to flood after it was stopped to the point that gas flows out the top and bottom of carb. After floating across the lake all night i finally figured out that it would run in full choke and made it home. I think this may be a result of the gasket that in at the base center of float tank in the bottom might be bad. The one on top of the adjustment pin.
Second question have you ever heard of any one modifying a newer carb to fit this motor because I?m having trouble finding parts.
1946Zephyr
Re: Johnson 1958 35HP Super Seahorse Carb Flooding
There are bunches of places to get kits for that. The local dealors in your area may not be stocked up with your parts, but there are lots of other places that are.
sea-way.com
engine blade and prop.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
tcoutboards.com
http://www.nymarine.ca/piclist.html Paint and decals
