johnson 18hp spark plugs
jdsgrog
Just wanted to make sure, but which plugs should I use for a '58 fd-12? J4C's or J6C's.
Vic.S
Re: johnson 18hp spark plugs
contiuouswave.com gives J4C.
J6C are just a little hotter. May be useful if you suffer from fouling.
tashasdaddy
agree^^^ also opening J4C to .040 will help fouling.
jdsgrog
thanks. I didn't see any problem with fouling. The motor came with j6c's, but I saw in the manual that the originals were supposed to be j4j's. I tried the j4c's and it ran fine at mid to higher rpm's. But it was the same with the j6c's. I think i'm going to have to rebuild the carb and clean out the low speed jets. I have a question about carb cleaners, but I'll ask that in another topic.
