I've been resurrecting a 1980 Johnson 15HP (model number J15RLCSD), which I bought knowing the telltale did not 'pee'. I assumed it would need a water pump anyway, so I am going to do that next weekend. Cool water comes out of the upper exhaust port, but the telltale does not pee. <br /><br />while running the engine and trying to flush it out, I ran a wire up the telltale port to make sure it wasn't blocked, and I noticed hot water/water vapor coming out of it. The motor did get a bit hot, so I shut it down.<br /><br />Should a water pump alone fix this problem? Water seemed to be coming out of the upper exhaust just fine, but hot water and water vapor dripped out of the telltale. I know it needs a water pump ANYWAY, but I'm wondering if I should be looking for something else as well.
