I need a service manual picture of how the spring is to fit into the gear that holds the starter cord. The end of my spring broke, and I do not know how to rewind it. I can reshape the end to fit into the notch in the bottom of the gear, but do I have to turn this gear to rewind the spring??? The spring itself never came out of the spring holding "pan". I do know from some one else the length of the starter cord which also needs to be replaced. I need a picture of which way the spring coils in the pan and whether or not it has to be rewound..Also, the brass grommet the starter cord passes through is worn through (frayed the starter cord) and this also needs to be replaced... can't get any local help!
