Johnson 15hp kicks at speed...any ideas? (Video)
galveston
I have a late 70's Johnson 15 outboard that "kicks" at speed/full throttle. This happens consistently and repetitively. If I back off the throttle just a touch, it ceases and the engine runs like a top.
I have been told it could be a clutch dog, prop ventilation/cavitation, spun prop, motor running lean, shifter link needs adjustment, etc.
You can hear it happening in this video from 00:19 to 00:30.
http://www.youtube.com/watch?v=b-2e3DW7g6Q
Are there anything tests I can do to verify the problem? When I spin the flywheel/prop by hand I can definately feel the gears catch and it feels solid. I have never had it slip out of gear. Anyways, I really like this motor and would like to fix this problem.
dew2
Re: Johnson 15hp kicks at speed...any ideas? (Video)
What do you mean by KICK,It seems it bogs down toward the end of the vid.unless thats you lettin off the throttle?
galveston
I got off the throttle.
By kick I mean the outboard jumps as if it is hitting something in the water. This happens repeatedly and it is not random. It does it consistently every time at full speed.
SparkieBoat
check sparks, compression and fuel..sounds fuel related to me..clogged carb maybe bad fuel line...also check your reeds
Faztbullet
That usually a lower unit/adjustment problem. Has it always done this or have you serviced anything and this just started doing this?
galveston
it has always done this since we bought it.
boobie
Sounds like a fwd gear and clutch dog.
galveston
thats what i keep hearing the most.
Faztbullet
Yep.... dog and gear get my vote. Find a good machine shop and have them recut as cheaper than gear and dog.
galveston
so should i just buy a used gearcase or should i get a mechanic to fix it?
jasper60103
I tell yah, if it popped out of gear I certainly didn't hear it.
My 25 did that once and it was a loud bang, and it scared the crap out of me.
kbait
Didn't sound like clutch bang to me either. Perhaps when the stator plate is advanced fully (full throttle), one plug wire gets close enough to a ground to arc out intermittently?? Check the plug wires when motor is off and motor is in forward and throttle fully advanced. May be a barely noticeable pin hole in one plug wire. It's also possible for the cylinder the fuel pump draws it's pulse from is getting too much fuel (leaky fuel pump diaphram). That would only affect one cylinder. Those fuel pumps are pretty universal, so perhaps you could borrow one for a test? Also, be sure all the ground wires are properly tightened down.. especially the ones from each coil to their mounting bolt. Good luck! Oh, and if it's a '74-'76, it has points under the flywheel (newer ones have a CD box). Dirty points could cause this, as could a stator plate w/lateral play, as that changes the point gap. If it's '77 or newer, that's not the issue.
galveston
Here is a great comparison. I have my doubts that it is slipping in and out of gear. I would think it would be more violent and that the lower unit would shred itself in no time.
Here is a nearly identical motor. Listen to it. Sounds smooth.
http://www.youtube.com/watch?v=VPUO1KEju-U&feature=related
Now my motor. Sounds, runs great at 90% throttle but soon as you go all out it starts "wahwahwahwahwah" and the motor kicks in sync with these oscillations.
http://www.youtube.com/watch?v=b-2e3DW7g6Q&feature=related
Still stumped.
jasper60103
Ohhhh! I can hear the "wahwahwahwahwah". At least we can eliminate the clutch dog. I'm not sure what it is though. :confused:
Can you post your model number, that way we can nail down the year?
galveston
Sure will, I can find the manual tomorrow.
jrs_diesel
I agree, does not sound like the clutch dog at all. Almost sounds like its hitting a rev limiter, even though these engines don't have them. Very strange.
bktheking
Is it a CDI motor, no points? If so , post the part number on the powerpack.
SparkieBoat
I still think post number 5 is a good place to start..that is not a clutch dog slipping.
