sullivanjm
- Dec 18, 2001
- 3
I have a 93 Johnson 150 that I use about every 4-5 weeks. Last time I took it out, I had a loose battery cable, so when I went out yesterday, it had been about 2 months since I had the motor running. It usually takes a few tries to crank it since I don't use it every week, but once it cranks, I have no problems. Yesterday was different!<br /><br />I can crank the motor, and if I don't put it in gear, I can idle it up to over 4000-5000 RPMs. However, when I put it in gear, it will only run at about 1500 RPMs, and won't get up any speed. After running at 1500 RPMs (in circles trying to warm the engine up) for about 5 minutes, it will die and I have to repump the fuel bulb and wait a minute or two to restart it (like it's flooded or something). I'm not a mechanic, but have the manual and have basic engine knowledge. Any suggestions for a "quick fix" try before I sink money in a mechanic to troubleshoot this?<br /><br />Thanks!
