ArtieFishel
- Apr 6, 2019
- 3
Hello Everyone. First time here. Hoping you guys can help me.
I have twin 2001 Johnson 150's. On a cold start they will start up fine and idle for the 10 minute ride out of the canal. They can cruise all day just fine. The problem comes after i shut them off for any longer than about 15 mins. They will start and run for a couple seconds but they will not idle. The only thing that seems to get them going is to put em in gear very quickly and feather or pump the throttle till they go and keep them above 1,100 RPM. After running they will idle again. It's only on warm starts after it has sat for more than 15 minutes that the problem shows up. It's difficult to try and go to lunch on the water when you cant idle away from the dock. Ive seen others with the same issue but never have seen a
