Outboard Engine - Johnson 150 V6 1988
When sqeezing the engine primer bulb-
I have a little gasoline comming out of the VRO pump directly above the gasoline input line. The gas comes out on from a little round disc at the top of the VRO pump. The engine runs good but is a little smokey. Does this effect the operation of the pump. I think it's only when I am sqeezing the primer bulb. I haven't checked to see is it leaks when the engine is running.
Does the leak let in air into the mix?
Is there a cheaper alternative to paying $320 for a new one.
