I have a 1995 Johnson Ocean pro, V6-loop charged, carb'd, VRO disabled (pre-mix), fresh power head & rebuild.
Have just rigged my boat, new moller gas tank, lines, fuel/water sep, primer bulb etc.....
Engine idles rough w/ sneezes and in the 800-2000 rpm range runs rough as if a cylinder may not be firing correctly...when I get on the throttle and get the rpms up, it runs smooth and like a scalded cat.
yesterday I disassembled carbs and cleaned all the bowls, floats, needles etc..did not appear to resolve anything (idled w/ flusher, have not water tested yet) Didn't find any suspect looking debris in the carbs...I suspected a sticking float. also cleaned out the in-line filter at the intake...minimal debris there.
Have shorted the quick start out w/ engine running, doesn't seem to effect the sputtering at idle.
Plugs look fine and are new. Fuel pump appears to be pulling fine (finger test of vacum on line pulled from fuel/water sep...next step is to put remote tank in and skip the onboard fuel tank, see if I can isolate any potential air leaks..
Short of a fuel issue, is there possibility of ignition circuit not firing right at lower rpm range?? Also, getting what I deem to be very poor fuel economy...about 1-1.5 mpg (pushing 1985 18ft. Mckee Craft CC 1500# hull wt.)
any help appreciated.
