I have a 1986 Johnson 150 outboard with the VRO system on a 1986 18' Cimmaron center console. Soon after purchasing the boat I had an alarm buzzer start to come on at various times. The boat mechanic I took it to told me that it was the fuel pressure warning buzzer. The way the boat is designed, the built in tank is in the front of the boat with the fuel line entrance in the front of the tank (away from the motor) and it is roughly 18 feet from fuel pick up to motor. The mechanic says the motor isn't capable of pumping the fuel that far and that there wasn't anything I could do. If you hook the boat up to a 6 gallon tank next to the motor, it runs awesome with no buzzer. The motor runs well until you get past about 3/4 throttle when the it will start to cut back from lack of fuel and the buzzer begins to go off. Because I just didn't believe the mechanic that a boat new from the factory wouldn't have been designed to operate properly, I began replacing parts. I've replaced every fitting, all the fuel lines from tank to motor, cleaned the fuel tank completely, fuel filter, VRO pump, all 3 carburators have been rebuilt, basically every part from fuel pickup to the motor has been replaced with no change in how the motor reacts. Sometimes the warning buzzer sounds at startup, but the motor idles fine, and other times it only cuts back and warns me at high speed. I'm stumped and need any advise someone might have. I've been told that I might help my issue if I lower the pitch on my prop since I"m running a little low on RPM's at max throttle (when I can get to max throttle). ???
