Good morning, I found one Johnson 14 hp engine manufactured in 1989 according to the nameplate. It is almost identical to model VJ14RCEC 1989.
For various reasons, it was never used, never been to water.
I changed as a precaution pump impeller and intend to change the gear oil . Lubed also all points with grease.
I haven't the engine manual and found nothing about it on the web.
As the photos below, I wonder what kind of electric conecction is that of three pins, I understood that is for charging battery , power any electrical circuit, or both. Anyone know how to use it? Volt & amp? And I have no idea of the type of outlet that is this and where to buy the other of the socket to fit the engine.
And I found a hole that seems to be obstructed, and I also have no idea if I should try to unblock it or is so.
thank you very much
thank you very much
