Hi
Whilst running the engine on muffs I have a strong tell tale but water coming from 2 or 3 locations between the lower end unit and the leg.
The water is warm so it has been around the engine.
I dropped the lower end unit and the impeller housing is showing no leaks. I did notice two rubber seals, one orange one black around a housing in the exhaust pipe.
Do they need to be changed to stop the leaks or is it just that engine is old?
I am not too concerned as the water is warm so it has been around the engine before leaking out and therefor is doing its job of cooling the engine.
Anyone have any thoughts?
Thanks
Thanks
