Johnson 140 V4 Cavitation ? Please help
Heavydem
Hi all, I have a Johnson 140 and am at an end with this problem. When I throttle up to get out of the hole, the engine over revs and I go nowhere. The prop is still turning but I am barely moving. If I ease on the throttle from neutral, and get on plane slowly, then I can run no problem. If I am pulling a tube and turn sharp, it does it again. People are telling me it is cavitating and my leg is too short?
1. I have had the lower leg inspected and rebuilt. No wear or gear issues found
2. Added a 'dolphin fin, no change.
3. Prop hub is not slipping
Any help would be appreciated. anyone tell me how long theirs measures if they have a 140 ?
thanks for any advice.
CarlW
Besides a slipping hub, this might be what's up.
I looked at a boat to buy last week and it did EXACTLY as you describe...on turns and everything. I told the seller thanks, but no thanks.
He texted me later after talking to an expert. The verdict? The prop had the wrong pitch.
SparkieBoat
the pic is not good but it appears that your motor is about 3 inches too high. a better pic from the back with the motor level
Heavydem
No Title
Thanks all for the responses.
1. I know the hub is not slipping because I marked the spline insert hub and the main hub then ran the boat. the marks were still lined up.
2. there is a 13x19 prop on it. Anyone know what it should be ? I have never tried a different one.....back to the lake for another test.
Here are a couple more pics. thanks again for any feedback.
cheers,
heavy
SparkieBoat
motor height looks perfect. if the prop is not slipping then the only other reason for slippage would be that you trim it up too much. you should prop it so that you run about 5800 RPMs at WOT. every boat will be a little different. I think that your prop might be slipping. put a mark on the prop nut and on the prop itself.
vasy
I have 140 v4 as well on a 18 footer fiberglass runabout, running 13x19 prop I can rev it between 5300 and 6200 rpm depending on the boat load and the acceleration is strong. We had no issues pulling a knee board behind.
So I'd say the prop size is about correct for the motor. Condition of the prop is a different story of course, can't comment on that.
