Re: Johnson 140 4 stroke (Suzuki) water pressure
Thanks Silvertip for your post and info!
I know the water pressure gauge didn't tell you much except the impeller is working, the reason I want to install a gauge is I am playing with the motor mounting height on the jack plate and need the know the water pressure before I jack the motor up too high and get overheated.
Any tips on where I can obtain the data on pressure (psi) at wot?
Thanks again!
Cheers
