SD Black Sheep
- Aug 8, 2013
- 12
Need some help. Got the lower unit back on: in reverse the prop locks both ways (think is normal right?), neutral spins freely, forward locks both ways.
Is this because the height of the shift shaft is off. I ended up messing with the height and then tried measuring to the manual's suggestions. Felt like is was pretty close on height but maybe not perfect.Used a homemade tool ( yard stick and long bolt)and not a proper measuring instrument.
Could this be the reason it seems to be in reverse (prop locks)when throttle goes in forward or is there any other guesses in what is going on.
