gregory bartlett
- Jun 29, 2001
- 2
I have a Johnson 125 HP, circa 71-73 and have owned it for about 10 years. Since I have owned it, I have never had any problems with it; it has always been very reliable. However last season it began to develop a problem and this season it has progressively gotten worse. The symptoms: the engine will run fine full throttle, half throttle or idle and then for no apparent reason just dies, no coughs or sputters, it just dies out. After a while it will start back up and run fine. I have had it to the local marina on three different occasions and they could not find anything wrong with it (although they are not Johnson/Evinrude dealers). Recently I took it to our closest Johnson/Evinrude dealer (100 miles away) and he kept it for a few days. It was his opinion that it needed new power packs, however he could not be sure. The price of the new power packs was going to be 350 dollars plus fitting, and he was not even sure that this was going to cure it. So as you can imagine, I am more than a bit reluctant to pay 350 dollars for something that might or might not work. Between us we have pretty much gone over the whole engine, plugs, fuel delivery, carb etc. and we still have the problem. Do any of you folks have any idea/suggestions? Or do you know where I can obtain a cheaper power pack? I certainly would appreciate your help.<br /><br />Thank You<br />Greg Bartlett
