Re: Johnson 120 Lower unit fluid
There are two identical looking large slotted screws in the gearcase; the top one is the vent and the bottom is the drain or fill plug.
Gear oil is always inserted from the bottom until it flows from the top or vent. When it flows out, replace the top screw first, then the bottom.
