Re: johnson 115
Check the carb bowl for gunk. If found, suspect this is also clogging the carb passages and jets. Your engine could be starving for fuel when you increase the throttle. Also, check the linkage for timing advancement, make sure it moves together with the movement of the throttle plates in the carb throat.
