Johnson 115 v-4 1983 speed jets
alcfer
Knows somebody if it is possible to check and clean the fixed high speed jets of my carburetor without removing it?<br /><br />Thanks for your replies
Brew
Re: Johnson 115 v-4 1983 speed jets
I think you are going to have to remove them...but that isn't very hard. <br /><br />You just need a big flat screwdriver to remove the float bowl drain plug, then a small flat screwdriver to remove the high speed jet.<br /><br />Good luck.
rodbolt
hello. it is possible to gert the drain screws out on most but next to impossible to get the lower main jets out. dont try a screw driver buy the jet driver. most screw drivers tear up the jet. I made my own jet driver but the one from omc works well. If all you wish to do is clear light debris use a can of carb spray with a long thin tube and some canned compressed air like for blowing off your keyboard. if it is anythhing more I would recommend removing the carbs for cleaning. remember all the pistons move but if one jet is partially clogged that piston get short on lube. and then it burns<br /> carb kits are much cheaper then pistons :) <br />good luck
clanton
You should be able to remove and clean the main jet without removing the carbuators, but what about the trash floating around inside the float bowl, that may be to large to flow thru the drain hole.
alcfer
Thank you very much to all. <br /><br />I will try to use a product to clean the carburetor and if it continues failing I will take it to the mechanic, since I don't feel sure to disassemble the carburetor and to fit it later. I'm looking at my clymer manual and there are some linkages after assamble the carburetor, very difficult for me.<br /><br />Anyway thanks to all again<br /><br />Fernando
rodbolt
hello fernando. the carbs are not hard. buy omc kits and it is straight forward. the linkage is very easy to adjust. I can help you though it if you wish<br /> I am putting a 115 togeather now and I can write down what you need to do step by step<br /> good luck and go for it
alcfer
Thanks Rodbolt<br /><br />I have the boat in my house of the beach. I will not go there until the next month of November and I can´t test the engine until then.<br /><br />If I decide to clean the carbs and if do you want I'll contact with you to obtain your help.<br /><br />Can you send me your e_mail.<br />My is alcfer@hotmail.com<br /><br />Thank you
