Thanks. Location : South Africa which is why I ask about parts. Will lookup Crowley & Evinr. Tx.
Had HT leads checked, timing sorted. Coils good.
Impeller & water pump awesome. Pumps water just on cranking at startup.
Noticed general consensus online backs Champion plugs. Battling to find.
NGK equivalent is H9S also a battle - opted for H8Sh - the non resistor one as per forums/info online.
Using mineral Outboard Castrol 2T NMMA certified TC-W3 what previous owner swore by. Seeing it is pre 2000.
Seems to have fuel starvation. Runs then bogs down. But when she goes "whoaaa!" Smooth. Amazing gearbox too.
An associate who has boat shop says the J115 carbs - even if you strip & find no dirt & clean - they suddenly work. Very sensitive carbs apparently.
Or time to check fuel pump?
Thanks once again.
Sounds like a 1990 model.-----Reread model #------Simple and very good motor when it left the factory.-----Install a new water pump impeller before leaving the dock.-----Any boat shop will get you the parts I think.-----crowley marine -----evinrudeparts.ca----- and this site you are on.-----your location?
