You have a 1978 115HP powerhead. The exhaust cover is a 115 piece as is the tag. Its also obvious that the engine has been cobbled together from different parts. 140's use different heads, a machined internal exhaust passage, a different exhaust cover and internal exhaust passage set and they have a set of rubber stuffers inside the intake manifold. Someone probably blew up their 140 and replaced it with a 115 powerhead. These things are 30+ years old and 140's never did grow on trees.. My 140's block has been replaced with a 115 block that has been machined to 140 specs but it still has the 115 tag.
A 140 ( and later 115's,112's and 110's ) will look like this from behind.
