Hi, I had my lower unit re-sealed about 2 weeks ago. I told them not to replace the oil, as I have a quart of HPF that I wanted to use.
I haven't gotten around to filling it up with oil yet, so it's been sitting for about 2 weeks or so without oil. I will be filling it up this weekend.
I was just wondering if it's a bad idea to leave the lower unit without oil in it, can anything rust inside there, even though it's just sitting in the garage?
I know they used some type of parts cleaner when they did the re-seal, because I can smell it and see it on the lower plug when I pulled it out. So it occured to me that any oil residue has been stripped off.
Also is there a good way to get any remaining parts cleaner out of the unit before I fill it, should I just pump some fluid in and then let it drain out and then fill it up?
Thanks for the help.
