Johnson 115 4 stroke peeing weak
The_Ursus
Just had the water pump replaced on my 2004 Johnson (Suzuki) 115 and it still has a weak stream, where else should I check? It seams like there is something blocking the flow internally since it's an intermittent problem. I've tried blowing on the line air will move through it but maybe not as freely as it should. Any suggestions?
Luke
tashasdaddy
Re: Johnson 115 4 stroke peeing weak
due for an impeller if it has not been changed. also run some weeder string up the tale tell opening.
The_Ursus
The water pump has been changed but it didn't make a difference. What about the pressure valve? It looks like a good place to collect debris or salt deposits. Is anyone familiar with the location of the pressure valve? I've found it on the parts diagrams but it's not clear where it's actualy located. I've got busy season ahead of me and I'd love to get this engine pee'n like a champ!
Thanks!
