Re: JOHNSON 100 ESL72
The grey wire runs all the way through the controller loom from the powerhead.. <br /><br />its specifically for the tacho.. and I can't imagine that you wouldn't have one since it is standard fixture on those motors, (according to the wiring diagrams I have amassed)<br /><br />all you need is ignition, earth and signal..<br /><br />if I remember correctly:<br />ignition => purple<br />earth => black<br />signal => grey<br /><br />all of those should be in your controller, (use a test light to get the ignition, because I vaguely remember seeing several purple wires. (they are probably all ignition)<br /><br />I got a meter or trailer cable (seven core) and ran that from control box to dash.. worked for me.
<br /><br />regards<br /><br />Frank
