JohnRude Gurus-electrical
walleyehed
Hey guys, got a '95 115 that had bad tach signal and eratic voltmeter readings well above 16 volts...this (thinking I'm so darn smart) led me to the reg/rect. which I changed out. Had some hard start issues so I done a thorough carb job w/kits. Had weak water pressure so I put a pump in too.
Several things happened on start-up....still hard starting even after linc-n-sync (and I pride myself on my abilities in that area,lol..) Water pressure is great at Idle, 2-3psi, right where I would expect, but voltage shows 18volts and at Idle on the muffs, tach shows 450 and I know it's above a 1000. Same thing I had before the reg/rect change. 13.9 volts at batt when gauge says 18 so I know I have an indication issue there.
Compression top 2 is about 120 each...a bit "high" to me...and the bottom 2 are 92 and 95...something ran through the lower carb I believe. Comp readings with throttle plates closed too!
Can a Stator have taken out the reg/rect., and now be bad enough to ruin a coil? should be 2 completely different circuts should it not?
#3 fouls quickly...put new plug in, runs a few minutes and is fouled again, yet spark tester doesn't show any missfire. Piston tops all look brown, no craters, very light carbon, very light-normal to me.
I'm going to try another coil on #3, and a tach and voltmeter....I don't think staor is bad because voltage is correct at batt when running, but could a bad Reg/Rect. take out the tach AND voltmeter??
tashasdaddy
Re: JohnRude Gurus-electrical
i do not like the spread of the compression.
yes, bad reg/rec can blow the tach and V/M.
trimmers
I might be wrong, but 120 on 2 cylinders is great, but having a 24-25% decrees in the bottom 2 cylinders is bad. I understand the rule of thumb is 10-12% difference between cylinders is the most acceptable spread. Might hear some rumblings about your numbers in replies here. Before you buy a new volt meter, if ya got a multi-meter, test the volts at the back of the guage with the motor running and see if the multi-meter reads same as battery or same as guage. Might not need a new guage. But I hope you do since that will be the least expensive fix. As far as the erratic tach signal... got me, I will let the pro's answer that one.
walleyehed
TD, this eng. was O/H'd about 6yrs ago by somebody else so I have no "real" history...gauges aren't an issue, got about 40 of each in-stock...
I've never had a bad Reg take out a voltmeter-the reason I asked, and yes, the voltage AT the gauge is the same as the Batt...gauge is shot.
Engine was fine most of last year...hard starting showed it's face in the fall. tach and VM quit about a year ago or so, but not at the same time...several months apart. I just finally got the guy to bring me the boat..
walleyehed
Disregard...found stator checked out bad. No resistance through stator leads unhooked and nothing from each lead to ground either....don't know how it ran at all.
Shop that O/H'd the powerhead installed new stator last summer...after removing and inspecting wires, I found 1 chaffed through and had been intermitently touching the block molding under the flywheel. He'll love the news on this one......
trimmers
Ouch! So the wire that was chafed ruined the stator? Or can you just repair the wire? I ask as a learning point for myself. If the stator is shot, wouldn't you have shown only battery voltage since the stator is the first component in the charging system?
walleyehed
13.5 is not batt residual....stator was putting something out on the ign. charge coil side or it wouldn't have ran at all. Stator also is AC current coming out...just touching once in a while would be uncontrolled discharge and likely would burn something up. By the manual, the stator is shot....hopefully I didn't take the reg/rect. out again...
