Johno 3 Hp paint questions
OMCFREAK
Gday i am restoring a 64 model 3hp and am about to repaint it but dont know what paint to use. i have repainted another outboard in DULON acrylic but it came off the gearbox when i tested it out. is 2 pack exopy good? and also i want to make new decals for it but need the proper paper does anybody know where i can get Decal paper like they use on AOMCI decals?<br /><br />Thanks
walleyehed
Re: Johno 3 Hp paint questions
I've had real good luck with Dupont Emron over Corlar epoxy primer..you won't have any problems with paint peeling off. I use a flexative in the Emron.
dajohnson53
You probably already know this, but what the hey.<br /><br />I repainted my (jet) lower unit last summer. I sanded all unsound paint off it down to bare, shiny aluminum and roughed up the rest. I removed all dust, grease, etc. with some solvent that I got at the paint store. I then primed the whole thing with a couple coats of the green aluminum primer. My understanding is that this priming has to be done ASAP onto the bare metal to avoid any oxidation. That's what I did - immediately primed. I then coated with several thin coats of the OMC white paint that I bought at the dealer. I looked at the can and it is just spray enamel. It turned out fine, although doesn't exactly match the white on the rest of the motor. I think I could have come closer with stock cans of white spray paint. <br /><br />One year running in freshwater, silty water and salt water and there is no evidence of the paint coming off. <br /><br />Good luck with your project. I'm about to start on making my old 74 Merc kicker look like new, if I can find some decals.
