Donnis Reese
- Jun 5, 2002
- 22
Joe, I have put a couple of posts on here concerning my 1972 65hp evinrude triumph not going into neutral or reverse. You gave me some info on checking the Solonoids I found the problem in the wiring harness got that fixed. Thanks alot. Then I changed the lower unit oil (with an oil that said it was OMC approved but it was not OMC Brand) and took it out. It worked great for an hour then it started popping in and out of gear in forwerd only. Is it true that when in forward there is no power to either solonoid on this hydro electric shift? Next I pulled the lower unit and pulled the clutch dog. I found probably 2mm of wear from the corners of the clutch dog. Would this be enough wear to cause this problem? I flipped this over to the other side (which showed wear also but not as much)put it all back and took it out...Still the same thing. popping in and out of gear in forward only. So the three questions I have are. <br /><br />On the hydroelectric shift would the type of oil used cause this problem?<br /> <br />How much wear on the clutch dog would cause this? <br /><br />Would changing to OMC brand oil fix this problem or is damage already done to the point of no return? <br /><br />Please help and thanks in advance.
