Joe Reeves and any other OMC gurus
eaw1952
Hi folks, Arco sent me the new trim motor, got it hooked up and good to go, they closed by the time I got the reservoir together and the motor is jammed, it appears to be a problem in the valve body.<br /><br />anyone talk me through trouble shooting that part, or have a schematic for it? <br /><br />2 gears, a couple ball bearings what could be wrong?<br /><br />any help would be fantastic.<br /><br />I'll be sitting at teh work bench with head in hands going 'hmmm' feel free to interupt!
OBJ
Re: Joe Reeves and any other OMC gurus
Hi ya' eaw....<br /><br />Partner....talkin' ya' through a troubleshot on a TNT body would be one hard thing to do. Ya' really need an OEM manual.<br /><br />Did you try running the motor before installing on the pump body? <br /><br />With the motor off the pump, see if you can turn the little shaft in the pump the motor connects to. You may also want to flush the system out. Drain what you can and see if the motor will turn the pump. <br /><br />But again, a manual would make things much much easier for ya'.
eaw1952
Oh, what I would give for a manual, believe me!<br /><br />The shaft turns fine alone, when I hook the valve body, or TNT I guess it's called? up the motor tries to turn but won't.<br /><br />putting a shaft in the TNT from the old trim motor I can not make it turn, it will go 1/16" one way and the same amount the other way.<br /><br />I just unbolted the 4 bolts holding the body together and yeah, the ball bearings got loose on me. <br /><br />anyway I'm in it now so try to talk me through it. I have the 2 gears, one is slotted to receive the shaft, I have three ball bearings and two springs and set into the base is a ball bearing that I can't get to move, I'm guessing there is a spring under it?<br /><br />one ball bearing is very small and I see where that goes, the other two are the same size and I assume they go over the two holes either side of the gears, did I lose a spring? I only have one that will fit those bearings.<br /><br />I don't understand yet how this works, I see the large spring with b.b. that is the return from the cylinders, I see the manual overide path, I don't see which hole is the feed?<br /><br />is the ball bearing that is 'stuck ' in the base suppossed to be free?<br /><br />putting oil in the feed and trying to blow it back out to see the route is doing nothing, neither is trying to find it from the other direction.<br /><br />hey give it a shot, I can be taught, you can always walk away if it gets to be too much for you!<br /><br />thanks!
OBJ
Partner....I don't have a manual here at the house and I sure wouldn't want ta' give ya any bad advice. Maybe one of the guys will have one that they can give you instructions from. Sure wish I could help more.....you are definitly have your "fare" share of motor problems this week.
rickdb1boat
eaw1952 <br /><br />You might try hailing Joe Reeves on this forum. He knows tons about thoses TNT units. Good Luck,<br /><br />EDIT: I see that in your topic now. Never mind.
eaw1952
Thanks guys!<br /><br />I must have dropped a spring, oh goody.<br /><br />motors? no no, boats leaking, trailers screwing me, it never ends.<br /><br />just another glorious day! I've had worse, lots. :D
Hooty
Yo eaw,<br /><br />Will this help?<br /><br /> <br /><br />c/6<br />Hooty
OBJ
Hooty....yer a real sweety!!
eaw1952
not yet. but thanks! I need one for a 1988 Johnson 40, model J40tlccs.<br /><br /> have one of those hooty? :( <br /><br />edit: it's the valve body to an Arco 6208 trim if that helps at all, I have no idea what the OMC # of that would be.<br /><br />sorry about that, I keep thinking I'm still in the original post on this.
Hooty
Don' got.<br /><br />c/6<br />Hooty
eaw1952
morning all, anyone know if omc/bombadier/whoever has tnt/ valve rebuild kits?
StarTekh
montreal here call OMC dealer here 101 years on the lake .. 514 457 3456 . remember its canadain money do the exchange. .cheep :eek:
eaw1952
Joe went on vacation, didn't he!?!<br /><br />edit: thanks John, no answer yesterday or today, I'll try on monday.<br /><br />the only hydraulic valve bodies I have found so far, in stock, are $180 with exchange. $250 for the motor and res. and another $200 is just too much, I'll go with out trim.<br /><br />or sell the motor. yeah, I'm liking that idea! anyone interested? :p
Joe Reeves
EAW.... No, I'm not on vacation, just a case that I have no idea what to tell you other than what you already know. The Oil pump is obviously jammed for some reason and will require replacing as it's not a serviceable item.<br /><br />My OMC book lists that component as being around $500 (Whew!). The prices you quoted are apparently discount prices, although it's still a tough pill ($$$) to swallow.<br /><br />When you get a chance, send me a few pictures of your pump to my e-mail address. I'd want to be able to view the manual release valve area, the two hydraulic line hook up areas etc.<br /><br />I have a couple oil pumps still in stock and might be able to help you with that problem. Just remind me of this post.<br /><br />ReevesJ32@aol.com
clanton
Did you try turning the pump with screwdriver, before you installed the motor. Sometimes the shaft is too long on the motor and will lock the pump.
Joe Reeves
EAW.... If you look closely at my last post, you'll see my e-mail address there (grin), but to repeat it..... ReevesJ32@aol.com .<br /><br />If you're speaking of the OMC parts manual picture, don't bother as I have all of that. I just assumed that you would have a digital camera and could click off a bunch of shots.<br /><br />Contact me and if you don't have a digital camera, I'll reply with some shots of what I've got and you can compare that with your pump.
