Donnis Reese
- Jun 5, 2002
- 22
Thanks Joe, <br /><br />I have been able to check the switch and it did work just fine. The shifter worked just fine then it sat for a yaer in a shed at my inlaws where it was knoked over on its side. I don't know how long it sat this way. could this clog somthing? Also I took the cover off of the coil hosing and applied power to each of them they do seem to work however the shaft that runs trough them does not slide up or down. should they or should they siply energise in order to move this "dog" ....Thanks for your help and please give more info if possible.
