Re: JH19! A mech shift converter for you.
Boomer, thanks for all that typing, man I do appreciate it. I wonder, can simple vibration of use send this into misalignment? <br /><br />When I bought the boat, I was told that a slight grind was normal when putting into gear, to go slow so as not to jamb it into gear. I have been extremely gentle with it, but it does not sound completey normal to me. I can see some noise but this is more than I think I should expect. <br /><br />I wonder then if being slightly out of adjustment, the drive jumped, just for a fraction of a second out of gear and right back in again. It has never jumped out of gear and stayed out, just a quick bump. Is this possible. Remember, the guy I bought it from had a meticulous shop, the boat was very well clean and winterized. You could eat off the motor. (He is an appliance tech). He hd not changed the impellor pump, nor had the drive off at all, was unsure when the last service was done by a shop. He owned the boat for 1 and a half seasons.<br /><br />BTW my manual says nothing of adjusting the cable after drive removal. Surprise surprise. I am going to print this and reinstall the drive, and adjust the cable. It will probably take me til mid week to finish. I hope that this is at least a good start to getting back on the water. Thanks again for your patience, looking for forward to your input on this.....again.....-Jeff
