Re: Jeep Wrangler...
V-8 Grand Cherokees of the 1st generation (1993-1998) are out there and are a dime a dozen. You have to check them carefully, though, look for issues with the trans, transfer case and rear axle exp on the 96-98s.<br />Now if you can live with less power, the 6 cylinder versions tend to be less troublesome and are even cheaper. You can find a nice 98 for maybe 6-7K or so at most. I like the 4.0 Six/Selectrac 4 wheel drive combination, there are tons of them out there, and with the right shocks, tires and airlift bags in the rear springs, it is fine for pulling 3000 lbs. Best thing is that they are simple and pretty easy to fix, and very similar to the Wrangler you have now. I do not like the electronic 4 wheel drive systems on many new pickups and suvs, they can crap out at the worst time. Selectrac is mechanical like the Command trac in the Wrangler, but it gives you a fulltime 4 wheel drive option in addition.<br />In addition to the usual Jeep issues, check the trans, and both axles for noises and leaks. Also check the AC, the evap coils on these often rust out. With the full time 4x4 they are superior for winter driving as well.
