Susquehanna Squid
- May 21, 2009
- 146
I am wondering if I have to remove the exhaust manifold in order to apply JB Weld. I have a 1988 3 liter OMC and water is shooting from just under the exhaust manifold (no water in oil thank God). Upon inspection I found that the last owner applied JB Weld to the same spot. The boat did not leak much at all last year but I am pretty sure that I did not remove all of the water before I put it away last winter. I know that i have to get the old JB out of there (as much as possible) and clean it up but it is a very tight space up in there. My question is: would it be OK to just apply as much JB Weld as I can up in there or should I attempt to remove the manifold. I am not a mechanic but am pretty good with the wrenches. The existing JB Weld is on the block and the manifold and it looks like it was applied pretty thick. Also, I do not care what it looks like just as long as it quits leaking. Any help would be appreciated!
