Re: Jazz Parts Resources
You can pick up 2 brass pipe fittings to connect garden hose to blk hose that passes around rear of engine....disconnect that hose from floor right angle fitting. Those fittings are $5 total at Home depot, Mercs fitting is $35 + shipping.
Thanks for the replies. The maual that I got from eBay is what looks to be a Mercruiser service book. Hopefully it will have some of the operation instructions for running the boat on the trailer. As far as the black hose that you're talking about, do you mean the one in the spring-clamp behind the engine cowl? I haven't hooked anything to it yet since I'm waiting on a starter to arrive to get the engine running, but I was assuming that that is the hose for running fresh water through the engine while running it out of the water. Or is that one just for back-flushing the engine after use? There is something similar on the back of my Four Winns Vista, but it's only for flushing the engine without it running. In fact, it's specifically for that purpose and to run the engine that way without muffs on the outdrive can cause damage.
That's exactly the kind of information that I'm trying to get in a manual. I'd rather look before I leap since about the only thing that I know for sure about SJs is that they're real different than I/Os and to mess with them without knowing what you're doing can get really expensive really quick. If you have any PDFs on anything useful it would be greatly appreciated. The only things that I have accumulated right now are the Bayliner Jazz parts list and an owner's manual addendum both of which are somewhat useless and the Mercruiser shop manual which hopefully will be a lot more useful.
The other two things that I really need right now are the steering cable and the diverter cable, the throttle cable is intact. The steering and diverter cables were removed, but never replaced on the boat by the previous owner. And the Boat/trailer were bought at auction.
Thanks again for the info.
