jackplate wiring - got to be a simpler way
SummerLark
This board is great. I read alot and do not post much. But I have a problem with my jackplate. (boat is a 200 Merc EFI on a 21 ft bay boat)<br /><br />The hydo jack plate quit working a while ago and lucking it was in a decent position. I left it alone for a year and now have the time to fool with it. It is a Detwiler plate with the old Exact Dial system for adjustment. It has a circuit board and all sort of wires. I believe after reading a bunch that the exact dial board and other related stuff is the root of the problem. <br /><br />Question is can I just wire a simple toggle switch to the pump motor and operate it just like a tilt/trim? And if so can any of you give me a link to a wiring diagram and some parts.<br /><br />Thanks -Dave
ed/il
Re: jackplate wiring - got to be a simpler way
Check the pump motor and see how many wires come out of it. How many amps does the motor use? You might need a solenoid ot two.
roscoe
You should be able to rig it like a tnt unit.<br /><br />A couple of relays, a switch, some wire.<br /><br />Might want to buy a wiring harness and relays from Mercury to save you the hassle and make it look nice.<br /><br />I'd buy a waterproof switch from them too. The kind the use for a remote tnt switch.<br /><br />You can buy a wiring harness from Mercury, part # 84-819514A7 $40<br /><br />And 2 relays at $12 each. part # 87-819509T
