Re: Jackplate And Prop Question
If the plate isn't convertable, I'd exchange it for one that is. You'll be amazed at what the 2.5 to 3 inches will do for balance.
As for a thru hub prop I'd suggest a Turbo. There was a series that they discontinued (Lightning Jr and the Pro Tour) that we might be able to locate. Email me at
dhadley50@aol.com -- I may have some suggestions as to where to look.
Most likely you'll end up with the propshaft centered somewhere near the pad. Your balance will determine the exact X dimension along with final prop choice.
Good choice over the V4.
Get a good jacket. A Lifeline preferably, and no -- a ski vest does not count. When you get far enough to test, hook the kill lanyard to the jacket and put tape around the snap. That way, in order for the motor to start the jacket will have to be close enough that it should be on, you won't be tempted to unsnap the lanyard and then forget to re-snap it.
You've got some work to do on the pad. Do it now, not later.
