four winns 214
- Oct 25, 2008
- 780
I've looked at a couple boats equipped with Jabsco manual pump marine toilets. Are these toilets suitable for head calls beyond routine bladder draining?
Yes! But there is a trick to it.
Preload the bowl!!!
Pour in 1/3 gallon of water before you have a seat.
You can also flip the lever to the left and pump a few times beforehand. That'll put water into the bowl.
Preload the bowl!!!
Yes! Good point, thanks for adding that. 100% of our boating is in salt water, 90% of our flushing is done with fresh water from a jug to eliminate the smell you get with brackish or salty water sitting in the waste tank.
