ajgraz
- Mar 1, 2010
- 1,858
Went through all the fuel feed lines on my (new to me) model year 2000 boat, to make sure everything was up to snuff:
1) Fuel line from tank to water separating filter (below deck) is Shields SAE J1527-A1, OK.
2) Fuel line from separating filter to motor (above deck) is Quicksilver (4000?) SAE J1527-B1, OK; and the bulb is a low-perm bulb based on part number lookup.
3) BUT...fuel lines under the cowling (2012 Mercury Optimax 125) is rated J30R9...is that OK? I can't find any references saying it is, only references to SAE J1527 for marine usage.
These fuel lines under the cowling certainly look factory to me. Everything I could find printed on them is:
EPA NAT-LEAPII 5/16" LP100 092612 13:41 SAE J30R9
So is that OK? Are you allowed to use line of this rating under an outboard cowling?
