J 110hp 89' choke setting?
dmurray
I was working on the motor and a friend adjusted the red lever on the choke inside the housing. Just curious if anyone knows where this is supposed to be set?<br />thanks
Solittle
Re: J 110hp 89' choke setting?
I think you have a primer rather than a choke though many refer to it as a choke. It should line up with the barell of the solinoid & is activated by pushing in the ignition key.
