Ridiculous
- Jul 26, 2010
- 50
i've got this '75 75HP johnson stinger. been foolin around tryin to figure out a misfire situation and it seems i'm getting nowhere! well, i shouldn't say nowhere, it does run better than it used to but it still has a miss and i'm not gonna quit until i figure it out.
here's the things i've done:
rebuilt carbs
replaced spark plugs
replaced all 3 ignition coils b/c 2 tested bad so i did em all
replaced rectifier b/c it had burnt up wiring
did a "link n sync"
inspected flywheel, stator, and timer base. didn't really find anything except rust. i cleaned the rust with sandpaper and re-assembled.
so now i'm in need of someone to tell me how to test the parts such as power pack, stator, timer base, etc.
i do searches but all the troubleshooting things i find don't help me because i don't understand what they're all talking about. so i need some advice and troubleshooting tips/ideas.
please be sure to use layman's terms for example: don't use "test DVA voltage" tell me what that is and what i actually need to do, because on every troubleshooting guide i look at, it talks about this and i have no clue what DVA voltage is or how to test for it!
thanks in advance for everyone's help...and please...help me hit the water before christmas
rebuilt carbs
did a "link n sync"
